The following LLDP TLVs are used to share the capabilities of the local device with its peers. LLDP is used for this communication. When a configured CEE map is applied to an interface, the capabilities of this device is shared with its peers to enable proper configuration of the ETS parameters. The following TLVs are available for use.
Priority Based Flow Control (PFC) Configuration TLV
ETS Recommendation TLV
ETS Configuration TLV
Link Aggregation TLV
