Configuring a CoS Mutation map on SLX 9740 and Extreme 8820
The following steps are only applicable to SLX 9740 and Extreme 8820.
To create a CoS Mutation map:
  1. Navigate to the Global Configuration Mode.
    SLX# configure terminal
    SLX (config)#
  2. Create the CoS Mutation map.
    SLX (config)# qos map cos-mutation test-cos-mut-map-1
    SLX (cos-mutation-test-cos-mut-map-1)#
    After this command is executed, the context shifts to the newly created CoS Mutation map context.
  3. Create the mapping entries as required.
    SLX (cos-mutation-test-cos-mut-map-1)# map cos 1 to cos 0
    Execute this command as many times are required to add the mapping entries.
  4. Exit out of the CoS Mutation map mode.
    SLX (cos-mutation-test-cos-mut-map-1)# exit
    SLX (config)#
    The new CoS Mutation map is created and is ready for use.
This is the consolidation of the above steps.
SLX# SLX# configure terminal
SLX (cos-mutation-test-cos-mut-map-1)# map cos 2 to cos 5
SLX (cos-mutation-test-cos-mut-map-1)# map cos 3 to cos 1
SLX (config)# exit
SLX#
