If a CoS-to-traffic class mutation map is not defined, the default CoS is used as value of the traffic class, and 0 is used for the drop precedence. For Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150 platforms, the supported drop precedence are 0, 1, and 2.
  1. Enter global configuration mode.
    device# configure terminal
  2. Create and name a CoS-to-traffic class map.
    device(config)# qos map cos-traffic-class cosTCMap
  3. Map ingress CoS value to the CoS-to-traffic class map traffic-class and drop precedence values.
    device(config-cos-traffic-class-cosTCMap)# map cos 4 to traffic-class 3 drop-precedence 0
    device(config-cos-traffic-class-cosTCMap)# map cos 5 to traffic-class 5 drop-precedence 1
    device(config-cos-traffic-class-cosTCMap)# map cos 6 to traffic-class 6 drop-precedence 0
    device(config-cos-traffic-class-cosTCMap)# map cos 7 to traffic-class 6 drop-precedence 1
    The drop-precedence parameter is mandatory.
  4. Return to privileged EXEC mode.
    device(config-cos-traffic-class-cosTCMap)# end
  5. Verify the configuration.
    device# show qos maps cos-traffic-class
    Cos-to-Traffic Class map 'cosTCMap'
             In-Cos  : 0  1  2  3  4  5  6  7
       TrafficClass  : 0  1  2  3  3  6  6  6
       DropPrecedence: 0  0  0  0  0  1  0  1
The following example summarizes the commands in this procedure.
