Applying a CoS Mutation map to a SLX 9740 or Extreme 8820
This feature is supported only on SLX 9740 and Extreme 8820.
The CoS Mutation map that needs to be applied to a SLX 9740 or Extreme 8820 must exist. If not, create the CoS Mutation map first. CoS Mutation Map can only be applied to the Egress side.
To apply a CoS Mutation map to a physical interface:
  1. Navigate to the Global Configuration Mode.
    SLX# configure terminal
    SLX (config)#
  2. Navigate into the interface context.
    SLX (config)# interface Ethernet 0/3
    SLX (conf-if-eth-0/3)#
    CoS Mutation map can only be applied to SLX 9740 or Extreme 8820 and only to their physical and port-channel interfaces.
  3. Apply the CoS Mutation map to the interface.
    SLX (conf-if-eth-0/3)# qos cos-mutation test-cos-mut-map-1
    The selected CoS Mutation map is applied to the interface.
  4. Optional: You can also apply the all-zero-map which is a special map that maps all incoming CoS values to zero (0) when applying to outgoing packets.
    SLX (conf-if-eth-0/3)# qos cos-mutation all-zero-map
  5. Exit out of the interface configuration mode
    SLX (conf-if-eth-0/3)# exit
    SLX (config)#
  6. Exit out of the Global Configuration Mode.
    SLX (config)# exit
    SLX#
The following is the consolidation of the above steps.
SLX (conf-if-eth-0/3)# qos map test-cos-mut-map-1
SLX (config)# exit
SLX#
