Egress ACL Rate Limiting
Important
The egress ACL rate
limiting feature is not supported on SLX 9150, SLX 9250, Extreme 8520, and Extreme 8720.
In general, you configure a rate limit profile by creating a QoS policy and associating it with
a QoS class map. Under this rate limit profile, you configure the expected rate. Egress
ACL rate limiting supports the following scheduling and shaping rules:
- Eight priorities for each rate limit profile and strict
priority for traffic in a rate limit profile (VLAN, BD, ACL).
- Traffic with the same priority destined to the same port but belonging to a
different rate limit profile is treated as round robin.
- Traffic with different priorities destined to the same port but belonging to a
different rate limit profile is treated as LOW (0-3) and HIGH (4-7). The device
supports strict priority between HIGH and LOW.
- All priority flows for a rate limit profile are under the same shaper. Each rate
limit profile shaping rate is aggregated for all priorities.
- Flows from all class maps, including normal traffic, are rate limited by the
configured port rate.
Table 1. Supported network topology for
unicast ingress and egress traffic
Ingress packets |
Egress packets |
Layer 2 port, VLAN or BD |
VPLS |
A VPLS or VxLAN egress topology is not
supported. Multicast traffic is not rate limited by the RL profile but it is rate
limited by the port rate limit.
