It is important that you connect the antenna leads to the correct antenna port on the AP. Use the following graphic and table as a guide when you connect your antennas.
Locate the antenna in the table below and, moving across the table, connect the specified antenna lead to the port.
| Antenna Part Number | AP4020X Ports | |||||
| Antenna Port 1 (6GHz) | Antenna Port 2 (2.4/5GHz) | Antenna Port 3 (6GHz) | Antenna Port 4 (2.4/5GHz) | Antenna Port 5 (2.4 BLE/5GHz) | Antenna Port 6 (5GHz) | |
| AI-TS06360 | N/A | Connect any antenna lead to any available port | N/A | Connect any antenna lead to any available port | Connect any antenna lead to any available port | Connect any antenna lead to any available port |
| AI-TQ08055 | N/A | Connect lead 1/A V-Pol to port 2 | N/A | Connect lead 2/B H-Pol to port 4 | Connect lead 3/C V-Pol to port 5 | Connect lead 4/D H-Pol to port 6 |
| AIO-DQ15021-RPSMA | N/A | Connect lead H-POL (top) to port 2 | N/A | Connect lead V-POL (right) to port 4 | Connect lead H-POL (bottom) to port 5 | Connect lead V-POL (left) to port 6 |
| AIO-DD05120-RPSMA | N/A | Connect lead Antenna#1: Left to port 2 | N/A | Connect lead Antenna#1: Right to port 4 | Connect lead Antenna#2: Left to port 5 | Connect lead Antenna#2: Right to port 6 |
| AIO-DD75060-RPSMA | N/A | Connect lead Antenna#2: Right to port 2 | N/A | Connect lead Antenna#1: Right to port 4 | Connect lead Antenna#2: Left to port 5 | Connect lead Antenna#2: Right to port 6 |
| WS-AI-DQ05120 (30702) | N/A | Connect lead "+45" to port 2 | N/A | Connect lead "-45" to port 4 | Connect lead "+45" to port 5 | Connect lead "-45" to port 6 |
| ML-2452-SEC6M4-036 | N/A | Connect lead "+45" to port 2 | N/A | Connect lead "-45" to port 4 | Connect lead "+45" to port 5 | Connect lead "-45" to port 6 |
| AI-TQ06120 | N/A | Connect lead 1/A V-Pol to port 2 | N/A | Connect lead 2/B H-Pol to port 4 | Connect lead 3/C V-Pol to port 5 | Connect lead 4/D H-Pol to port 6 |
| AI-DP04360S | N/A | Connect lead 1 to port 2 | N/A | Connect lead 2 to port 4 | Connect lead 3 to port 5 | Connect lead 4 to port 6 |
