Your Extreme access point ships with everything that you need for a basic installation. All optional brackets and accessories are sold separately.
| Quantity | Item |
| 1 | Extreme AP4020X |
| 1 | Regulatory document for your access point |
| 1 | AH-ACC-BKT-AX-TB bracket |
| 2 | Phillips pan head wood screws |
| 2 | Phillips head plastic screw-in anchors |
| 4 | AI-TS06360 Antennas (6dBi Indoor Quad Sector 120 Degree Tri-band with RP-SMA) |
