Antenna Specifications
The AP4020X supports the following antennas.
Integral:
External:
  • Two (2) dual band 2.4 GHz and 5 GHz
  • One (1) dual band 2.4 GHz (IoT Radio 1) and 5 GHz
  • One (1) single band 5 GHz
The single band 6 GHz integral antennas are only used in Mode 1. The dual band antennas are used in both Mode 1 and Mode 2.
Internal:
  • IoT Radio 1: Selectable between internal and external
  • IoT Radio 2: Two (2) selectable internal antennas (for channel sounding)
  • One (1) 2.4 GHz/5 GHz/6 GHz sensor
