The LED status light shows the AP's operating status. A solid white means that the AP is working normally. A solid or blinking amber indicates an issue.
The following table shows the LED states based on your firmware platform.
| Status | Activity |
| Dark | Power is off. |
| Solid white | The device power is on and the AP is ready to use. The device has successfully established a Control and Provisioning of Wireless Access Points (CAPWAP) connection to ExtremeCloud IQ and is operating normally. |
| Solid amber | The power is on and the AP is in boot up mode, or is running without a CAPWAP connection. |
| Fast-blinking amber | The IQ Engine firmware is updating. |
| Status | Activity |
| Dark | Power is off or the AP is taken over by the controller. Configuration pushes down to AP from Controller to turn off the LED. |
| Solid white | The AP is starting up or is already taken over by the controller. |
| Flashing fading white | Configuration pushes down to AP from controller helping the user locate the AP by sight. |
| Solid amber | A firmware upgrade is occurring. |
| Fast-blinking amber | The AP is acquiring the DHCP IP. |
