Extreme Networks access points have been designed for a quick and easy deployment. But you can make the process even easier with a little preparation.
Before you install your AP, do a site survey and coverage map so you have identified and addressed any potential issues. Here are a few issues that you should consider before you install the AP.
For more information on site surveys, see the Knowledge Base article What is Wireless Site Survey and why is it important?
If you plan to use Power over Ethernet (PoE) then confirm that it meets the AP's requirements. See "Power Profile".
Confirm cables meet or exceed the required specifications.
