Power Profile
The following tables show the AP4020X power profiles for the radio modes. Use this information to plan for power consumption as you deploy your APs.
BLE/5G-5 antenna is active when BLE is enabled.
Table 1. AP4020X 802.3at Power Profile - Power Status Normal|
| Radio 1 | Radio 2 | Radio 3 | 1x1 Sensor | Ethernet Port | USB |
| Radio Mode 1 | 2.4GHz (17dBm), 2x2 | 5GHz (18dBm), 2x2 | 6G (18dBm), 2x2 | Yes | Yes | 2.5 |
| Radio Mode 2 | 2.4GHz (17dBm), 2x2 | 5GHz High (16dBm), 2x2 | 5GHz Low (16dBm), 2x2 | Yes | Yes | 2.5 |
Table 2. AP4020X 802.3bt Power Profile - Power Status High|
| Radio Mode 1 | 2.4GHz (17dBm), 2x2 | 5GHz (18dBm), 2x2 | 6GHz (18dBm), 2x2 | Yes | Yes | 2.5 and 5.0 |
| Radio Mode 2 | 2.4GHz (17dBm), 2x2 | 5GHz High (16dBm), 2x2 | 5GHz Low (16dBm), 2x2 | Yes | Yes | 2.5 and 5.0 |
Table 3. AP4020X 802.3af Power Profile - Power Status Low | Radio 1 | Radio 2 | Radio 3 | 1x1 Sensor | Ethernet Port | USB |
| Radio Mode 1 | 2.4GHz (17dBm), 2x2 | No | No | Yes | Yes | No |
| Radio Mode 2 | 2.4GHz (17dBm), 2x2 | No | No | Yes | Yes | No |
