You will need a Ethernet cable. Locate the Ethernet ports on the AP before you begin. See
Ports and Connections.
Connect the AP to your network using one of the Ethernet ports and a network cable.
- Connect the Ethernet cable to one of the Ethernet ports on the AP.
- Connect the other end of the cable to the Ethernet port on the switch.
