Use the information below when you order your AP.
| Part number | Description |
| AP4020X-WW | Indoor Quad Radio Wi-Fi 7 (2x2:2): 2.4GHz, 5GHz, 6GHz and dedicated sensor, Multi-Rate, Ext antennas: 2.4GHz and 5GHz ports Integral on 6GHz port. Extended Temp, 4 dual banded ant incl, T-Bar Incl Mt (AH-ACC-BKT-AX-TB). Domain: World SKU |
| AP4020X-WW-TAA | Indoor Quad Radio Wi-Fi 7 (2x2:2): 2.4GHz, 5GHz, 6GHz, dedicated sensor, Multi-Rate, Ext antennas: 2.4GHz & 5GHz, Integral on 6GHz, Extended Temp, 4 dual banded ant incl,T-Bar Incl Mt (AH-ACC-BKT-AX-TB). Domain: World SKU TAA Compliant |
