Access Points and Switches are automatically added to via the
cloud-connector when the DHCP and DNS prerequisites have been met. You can use the
Add functionality to pre-provision any AP or switch before they connect.
To add a switch to your network:
Per-configure your external DHCP and DNS servers on your network for discovery
of the new switch. In order for the to communicate to the ExtremeCloud IQ Controller:
- The DHCP Server (that
will be serving an IP to the switch) needs to return a DNS Server and
Domain Name to the switch.
- The DNS Server needs to
map the name
extremecontrol.<domain-name> to the IP address of
the ExtremeCloud IQ Controller that you plan to add the switch.
- Confirm that the DHCP
server is serving the correct DNS and domain name information.
Go to .
Select Add and configure
the parameters.
You can clone a switch from
within a site, see
Switches.
Configure the following parameters.
- Serial Number
- Unique number that
identifies the switch. Provide this
number for new and cloned switches. This number is on the
switch.
- Model
- Select model number from the drop-down list. The
model number is on the switch.
- Name
- Unique name for the
switch. Provide a unique name.
- Description
- Text description to
help identify the switch.
Select OK.
Connect your switch to the network and power it on.
The switch must be reset to factory default configuration. Refer to the
switch documentation to reset your switch to factory defaults.
