Logging event reporting uses the logging protocol to relay event messages to a centralized event server on the enterprise network. In the protocol, a device generates messages, a relay receives and forwards the messages, and a logging server receives the messages.
Enable Report Station Events to collect and display station session events on the ExtremeCloud IQ Controller station events log.
Enable Forward Station Events as Traps to notify the administrator of events without solicitation. An SNMP trap is an event notification sent by the managed agent (a network device) to the management system to identify the occurrence of conditions. Traps can save network resources by reducing SNMP polling.
Provide the following for 1-3 servers:
10.20.30.40), or a fully-qualified domain name (FQDN) (e.g., some-domain.com).Secure — Select the check box to enable secure connections to external servers over TLS or DTLS.
A Trust Point must be pre-configured in order for it to appear in the drop-down list. See Trust Points.Enable the type of messages that you want to send to the syslog servers.
To synchronize the logs, the syslog daemon must be running on both the appliance and on the remote logging server. When you change the log level on the appliance, you must modify the appropriate setting in the logging configuration on remote logging server.Facilities codes identify log streams in the remote logging server. Select a unique facility code (local.0 - local.6) for each ExtremeCloud IQ Controller facility to differentiate the log streams and facilitate the filtering of messages.
