A VLAN defines how the user traffic is presented through the network interface.
To configure a VLAN:
| Field | Description |
| Name | Provide a unique name for the VLAN. |
| Mode | Bridged@AC — The ExtremeCloud IQ Controller bridges traffic for the station through its
interfaces, rather than routing the traffic. For B@AC, topology the station's "point of
presence" on the wired network is the data plane port assigned to the topology. Bridged@AP—Assigned to APs, the AP bridges traffic between its wired and wireless interfaces without involving the ExtremeCloud IQ Controller. The station's "point of presence" on the wired network for a bridged at AP topology is the AP's wired port. Fabric Attach—The Fabric Attach topology type allows an AP to attach to a Shortest Path Bridging (Fabric Connect) Network. The client component on the AP communicates directly with the server on an edge switch (or it can communicate with the server through a proxy) to allow the AP to request VLAN to I-SID (backbone Service Identifier [IEEE 802.1 ah] mappings). The Fabric Attach topology type is similar to B@AP with the added I-SID parameter. Fabric Attach can be configured on the ExtremeCloud IQ Controller anywhere a B@AP topology can be configured. VxLAN—VxLAN is a network virtualization technology that leverages existing
Layer 3 infrastructures to create tenant overlay networks. VxLAN addresses the requirements
of a multi-tenant data center network infrastructure by:
| VLAN ID | Specify the VLAN ID. Note: It is possible to configure a unique VLAN
ID when configuring a role. This provides more
flexibility in the Contain to VLAN default Action.
A unique VLAN ID is also required for a GRE topology. The VLAN ID range is (1 - 4094). 4094 is reserved for Internal VLAN ID. |
| VNI | For VxLAN. VxLAN Network Identifier. The VNI is a 24-bit identifier. It can be used in more than one VxLAN topology. |
| Remote VTEP | For VxLAN. The IP address of the tunnel End-Point is referred to as a VxLAN Tunnel Endpoint (or VTEP). The VTEP is the IP address of the network switch. Network switches that act as a VTEP are referred to as VxLAN gateways. There can only be one VTEP per VxLAN topology. |
| I-SID | For Fabric
Attach. A unique VLAN identifier and a unique I-SID (service identifier). The
I-SID range is (0-15999999). Use I-SID = 0 to support Fabric Attach Standalone Proxy mode on Extreme Networks Ethernet Routing Switches. Standalone Proxy mode indicates that the network does not include a Fabric Attach Server switch (and therefore does not include a Shortest Path Bridging Fabric Core). |
| Tagged Traffic | If you have more than one VLAN on a port, enable tagging to identify to which VLAN the traffic belongs. Ensure that the tagged vs. untagged state is consistent with the switch port configuration. Fabric Attach topologies are always tagged. |
| Port | The port for network traffic
bridged at controller (for example, physical ports: Port0,
Port1, Port3, Port4). LAG ports are supported on physical appliances only (LAG1, LAG2). When the VLAN uses a Port that is then added to a LAG, use the LAG as the VLAN. |
| Layer 3 | Check this box when configuring
parameters for the network layer (B@AC). Note: The Certificates button displays to
configure browser certificates for captive portal
security.
| Layer 3 Parameters | |
| Remote Settings: IP Address | The IP Address of a remote server on which the VLAN resides. |
| IP Address | IP address of the
VLAN. Wireless clients can access ExtremeCloud IQ Controller via this IP address. Note: The following subnets are reserved for
internal communications and Docker operations:
The ExtremeCloud IQ Controller user interface logic prevents adding addresses in these address ranges for VLAN interface references. |
| FQDN | Fully-Qualified Domain Name |
| CIDR | CIDR field is used along with IP address field to find the IP address range. |
| DHCP | Dynamic Host Configuration Protocol allows network
administrators to centrally manage and automate the assignment of IP addresses on the
corporate network. DHCP sends a new IP address when a computer is plugged into a different
place in the network. The protocol supports static or dynamic IP addresses and can
dynamically reconfigure networks in which there are more computers than there are available
IP addresses. Valid values are:
| Enable Device Registration | Indicates that the wireless AP or switch can use this port for discovery and registration. |
| Mgmt Traffic | Indicates that this port will be used to manage traffic. Enable Mgmt Traffic to access the ExtremeCloud IQ Controller user interface through this port. |
| Associated Profiles | Select |
Section contents:
