The Test Run tab lists all configured test runs.
From the Test Run parameters screen, select the wired or wireless environment and the network to test.
Important
AP service is interrupted when running tests on a wireless network.When running tests in Wireless Client mode, the selected AP stops offering WLAN service and becomes a client to the pre-confgured SSID (subject to compatible Privacy settings configuration).
To test a wireless network, configure one or more of the access points as a Probe AP. The radios on the Probe AP are configured to emulate a mobile user. Effectively, the Probe AP becomes the client of the other APs in the network.
Before you begin, understand the AP floor plan. When testing a wireless network, you must be aware of where the Probe APs are located and the name of the network SSID to which they will connect. The Probe APs should be evenly dispersed across the testing area.
When running a wireless test, select the Probe AP that is located in or near the physical location of the test. The Probe AP switches to client mode and searches for the network SSID for connection to the test network, on the defined Wi-Fi band (2.4 GHz, 5 GHz, or 6 GHz).
APs configured for Client Bridge or Mesh Networking are not supported as Probe APs.Section contents:
