To copy an upgrade or backup image to
ExtremeCloud IQ Controller,
configure the following parameters:
- Image Type
- Indicates the type of
image file used. Valid values are:
- Destination
- Destination of the
uploaded image file:
- Local
- Flash (The Flash
drive must be mounted.)
- Upload Method
- Method used to upload
image file to appliance. Valid values are:
- HTTP — Indicates
to upload from a local workstation.
- FTP — Indicates
to upload from the corresponding server.
- SCP — Indicates
When the Upload Method is FTP
or SCP, configure the server properties.
- Copy Image from Local Drive
- When the Upload Method is
HTTP, drag image onto ExtremeCloud IQ Controller or
select field to navigate to local file directory.
- Select Image
- Due to a storage space
limitation, ExtremeCloud IQ Controller limits the number of locally available
upgrade archives. If necessary, you can delete an older image before you
upgrade to the latest image. To delete an image from ExtremeCloud IQ Controller, from the Select
Image field, select an image and click
