The information that displays on the
Switch Configuration
page depends on the Switch Mode. By default, switches are in GUI-Mode. To configure
an
ExtremeXOS switch through the CLI, you can place the switch in CLI-Mode.
For more information, see
CLI - Mode Advanced Settings.
CLI-Mode support is
limited to
ExtremeXOS switches.
To access the switch configuration page:
- Go to and select a switch (not the check box).
For switches that are
not in CLI-Mode,
ExtremeCloud IQ Controller displays a list of ports on the Switch
Configuration page. From the configuration page, create LAG
groups and select the Admin state, Port Function, and PoE of each
port.
For each port, the system displays the following information:
- Admin State
- Name
- Alias Function
- Speed
- Neighbor
- LAG Members
- PoE
- Select one or more ports from
the list, and then set the Admin State, Port Function, and PoE options to
On or
Off.
Select Apply after each selection.
Switch in CLI-Mode:
After placing an
ExtremeXOS switch in CLI-Mode, the
page display is limited to the following buttons:
- Activate
Console. Opens a remote console for a live SSH console
session.
- Backups.
Displays a list of switch configuration backup files. From this list you can
view a file or restore a configuration from a backup file.
- Create
Backup. Create a backup file of the switch configuration.
- Advanced. In
CLI-Mode, switch advanced settings are limited to changing the switch mode.
From here you can select Change to
GUI-Mode.
