Configure policy rules that are associated with a role from the Role
Configuration page. To configure an OSI Layer 2 rule, which filters
on MAC Address:
- Select the L2 drop-down and
select New
or select the rule to edit and existing rule.
- Configure the following parameters:
- Name
- Name the rule.
- Action
- Determines access control action for the
rule. Valid values are:
- None - No role defined
- Allow - Packets contained to role's default action's
VLAN/topology
- Deny - Any packet not matching a rule in the policy is
dropped.
- Contain to VLAN - A topology to
use when a network is created using a role that does not specify a topology. (Not applicable for L7
Application Rules.)
- COS
- Determines the importance of a frame while it is forwarded
through the network relative to other packets. The CoS defines actions to be taken when rate
limits are exceeded.
- MAC Address Type
- Indicates if the MAC Address is user defined or any MAC Address.
User Defined enables the MAC
Address field for user input.
- MAC Address
- Media access control address.
Sometimes known as the hardware address, is the unique physical address of each network
interface card on each device. Specify the MAC address of the wireless client.
- Select
Save.
All rule types are
applied to the policy in top to bottom order. The policy is installed on the
enforced APs.
