RTLS Settings
A Real-Time Location System (RTLS) profile must be configured and enabled within ExtremeCloud IQ Controller before ExtremeCloud IQ Controller will communicate with the location-based server and before the APs will perform location-based functionality. ExtremeCloud IQ Controller supports the following location-based solutions:
  • AeroScout
  • Ekahau
  • Centrak
  • Sonitor
Configure the AP to integrate with a Real-Time Location System (RTLS).
  1. Select the plus sign to create a new profile ().
  2. Configure the following parameters:
    Table 1. RTLS Parameters
    FieldDescription
    NameProvide a name for the RTLS profile.
    ApplicationSelect a supported RTLS application. Valid values are:
    • AeroScout
    • Ekahau
    • Centrak (Supported on AP39xx only)
    • Sonitor
    Server IP Address The IP address of the RTLS application server.
    Server PortServer port of the RTLS application server.
    Multicast MACMulticast MAC address for the RTLS application server.
    Note: Centrak and Ekahau configuration offer a default port number and multicast address. You can modify the default values if necessary.
  3. Select Save.
Consider the following information related to Real-Time Location System (RTLS):
  • Ensure that your location-based service tags are configured to transmit on all non-overlapping channels 1, 6 and 11 (and on channels above 11 where allowed). For information about proper deployment of the location-based solution, refer to the third-party documentation (AeroScout/Ekahau/Centrak).
  • Within an availability pair, tag report transmission pauses on fail-over APs until the APs are configured and notified by the location-based server. With an availability pair, it is good practice to configure each ExtremeCloud IQ Controller with the same location-based service.
  • An RTLS profile cannot be deleted when it is part of an active configuration profile.
  • You can create up to 100 profiles.
