Certain actions can be applied to any number of APs associated with a site.
Go to either Monitor > Sites or Configure > Sites, select a site, then select Access Points.
Select any or all APs in the Site Access Points list, then select Actions and choose from the following options:
Assign to Floor — Enter the site floor number to which you want to assign the selected APs.
Image Upgrade — Select from the list of AP version images and apply to selected APs. If more than one AP is selected, the upgrade image must be common between the selected APs. If not, a message displays indicating that there is no common image. Download appropriate image or select different APs. For information on downloading an upgrade image, see Software Upgrade.
Minimize service impact is enabled by default.There is a delay of 180 seconds between upgrading each set of APs. APs serving DFS and Weather channels are upgraded within a 9-minute interval.
Delete — Remove selected APs from this site.
Reboot — Restart the selected APs.
