A device template provides a diagram of the physical ports for a specific Universal device and allows you to specify its functionality. For example, after you configure a device template for a specific device type, you assign its ports to various port types. A port type defines how the ports assigned to it will function. You configure the default port settings and other device functions and apply these settings to large numbers of devices of the same type. If you want to apply different device templates to other devices in the same network policy, you can do so.
You can make use of default templates, which are pre-loaded in ExtremeCloud IQ for every device model. The available template list expands as you create new policies. You can then use the same template for another policy.
If you select a default template, you must copy it by saving it as a new template. This will carry all the settings in the default template and let you customize it as required.
For the purposes of this document, the configuration instructions that follow apply to creating a device template from scratch, not starting with a cloned default template.Section contents:
