Use ExtremeCloud IQ to modify switch templates at the
device level. Settings made at this level (Manage > Devices > switch_name > Configure) apply only to the device and override the template settings configured
in the network policy. If you undo the device-level settings, the device automatically
reverts back to the original network policy and device template configuration. To revert
to the settings in the network policy, select Actions from above the
Device List. To configure settings at the network policy level, see Configure the Network Policy.
After you select a switch from the Device List, you can create or modify the following
for the specific device:
Device
Configuration: edit device details such as the host name, the
description, the device function, IP addresses, and VLAN assignments. See Configure Devices.
