Configure STP Settings
Use this task to configure Spanning Tree settings.
  1. For STP Mode, select one of the following:
    • STP: Uses a single spanning tree without regard to VLANs. After convergence, only the root bridge sends configuration BPDUs, and other switches only relay those BPDUs.
    • RSTP (Rapid STP): Uses a single spanning tree without regard to VLANs. After convergence, all switches send BPDUs every two seconds in the event of a physical link failure.
    • MSTP (Multiple STP): Can map a group of VLANs into a single multiple spanning tree instance (MSTI). MSTP uses BPDUs to exchange information between spanning-tree compatible devices, to prevent loops in each MSTI by selecting active and blocked paths. Configure MSTP settings.
    Table 1. Settings for MSTP
    Section Options
    MSTP Region
    • Select Use Default MSTP Region radio button to use the MAC address of the switch that will be used as the default MSTP Region
    • Select the Use a custom defined MTSP Region radio button, to enter a customized region into the text field.
    MSTP Revision Enter a value from 0 to 65536 into the text box. 3 is the default.
  2. Select an STP Bridge Priority from the drop-down list.
    Every switch taking part in spanning tree has a bridge priority. The switch with the lowest priority becomes the root bridge. If there's a tie, the switch with the lowest bridge ID number wins. The ID number is typically derived from a MAC address on the switch.
  3. Set the following STP Timers parameters:
    Forward Delay: The time the switch spends in the listening and learning state.
    Max Age: The maximum time before a bridge port saves its configuration BPDU information.
