Use this task to create ports in bulk.
| Setting | Description |
| Port Type | Enter a Port Type name. |
| Port Status | Toggle Port Status On or Off. |
| Auto-Sense | Toggle Auto-Sense
On or Off (Fabric Engine device only). Auto-Sense detects connected device types and automatically configures specific port settings. Certain port settings are not configurable. |
| Port Usage Settings | Select one of the following port types:
| Access Port | For an Access
Port, select an existing VLAN or select the add
icon to add a new one. Tag the VLAN to a particular access port to control and monitor switch traffic. To add a new VLAN, see Configure VLAN Settings. Note: For Switch Engine the none
keyword is available for entry as a VLAN. Alternatively, a
common object VLAN can be created with the VLAN ID using the
none keyword. Using none
removes the assignment of the native VLAN from the
port.
| Trunk Port | For a Trunk
Port, select an existing Native
VLAN or select the add icon to add a new
one. The native (untagged) VLAN is the VLAN assigned to frames that do not have any 802.1Q VLAN tags in their headers. By default, Extreme Networks devices also use VLAN 1 as the native VLAN. To add a new VLAN, see Configure VLAN Settings. Note: For Switch Engine the all
keyword can be used. Using all
will automatically tag VLAN IDs to the ports that are also
defined within other port
types assigned to the Switch Engine device.
| Allowed VLANS | For Allowed VLANS, enter a specific number or leave the All default. |
| Phone with Data Port | For Phone with Data Port (Voice): This option
offers additional CDP advertisement options within VLAN
settings.
Note: If the
LLDP/CDP options are enabled, then CDP/LLDP options within
Transmission Settings are automatically
enabled.
| Transmission Settings | Under Port
Settings, for Transmission
Settings, configure the following:
| STP | For STP:
Note: The
port is re-enabled automatically when time
expires.
| Storm Control | For Storm Control:
| MAC Locking | For MAC Locking, enable the per port type with the
option to specify Maximum
First Arrival Limit and specify the Link Down
Action. By default, Link Down Action is set to clear first arrival MACs, with the option to retain MACs. We also have the option to take action when MACs are aged out. Note: MAC Locking
must also be enabled on a per-port basis within a port type.
| ELRP | For ELRP Enabled, toggle to ON to enable ELRP per port (disabled by
default). Switch Engine switches support the ability to configure ELRP Exclude on a port type which will not allow ELRP to disable the port when ELRP packets are received. |
| PSE | For PSE, select an existing profile or select the plus sign to add a new one. For more information, see Configure PSE Parameters |
| POE Status | Toggle POE Status to the required setting. |
Section contents:
