Stacking is a proven technology commonly used for increasing port density in a wiring
closet. It simplifies the management of all the switches within the stack using a single
IP address. You can stack up to eight switches. You can create a switch stack for Switch Engine
devices only. You can create stacks automatically or manually, as long as they are of
the same configuration.
