You can configure switch ports in bulk or on an individual basis. If you choose bulk
configuration, you can use existing port types or create new ones. You can also
configure multiple ports at the same time. The following rules apply to bulk port
configuration for:
Copper ports must be of the same
speed type.
Selected ports with different maximum
speeds can now be part of the same aggregation.
Warning messages appear if your port selections do not follow these rules.
The following configuration options are available:
Port Details
Instant Secure Port
Port Settings
STP
Storm Control
MAC
Locking
Voice
ELRP
PSE
Attributes
BPDU Restrict and BPDU Restrict Recovery settings are found within the STP
settings.
For switch stacks, repeat all applicable port configuration steps for each
device in the stack.
