ExtremeCloud IQ v25.2.0 Universal Switch Deployment Guide
Configure Device-Specific Settings
> Web SSH
Extreme Networks, Inc. March 16, 2025
Abstract
Preface
Overview of Universal Switch Deployment in ExtremeCloud IQ
Deploy Universal Switches
Onboard Switches
Create an Account
Configure Firewall Access
Deploy Devices to the Cloud
Create a Topology Map
Change the Network Operating System
Quick Add Devices
Device Management
Configure the Network Policy
Create a Network Policy
Configure Policy Settings
Configure Switch Common Settings
Port Type Settings
VLAN Attributes
Configure a Device Template
Perform Device Configuration
Configure STP Settings
Port and VLAN Configuration
Configure Ports in Bulk
Configure VLAN Settings
Configure a Classification Rule
Add a Cloud Config Group
Configure PSE Parameters
Aggregate Ports
Configure Ports Individually
Universal Port Stacking Support Mode
Configure Advanced Settings
Configure Supplemental CLI
Configure Management Server Settings
Configure a DNS Server
Configure an NTP Server
NTP Server Settings
Configure an SNMP Server
SNMP Settings
Configure a Syslog Server
Syslog Server Settings
Configure LLDP and CDP Policy Settings
LLDP and CDP Settings
Deploy a Network Policy
Instant Port Profiles
Instant Port Profile Switch Template Configuration
Device-Level Configuration
Instant Port Profiles Delta Configuration Example
Instant Port Profile Example Workflow
Example Deployment Scenario: Optimizing Network for an Office
Example Deployment Scenario: Unmanaged Switch or Hub with Two Different Devices
Instant Port Profiles Troubleshooting
Hardware and Software Requirements
Scaling
Instant Secure Port Profiles
Creating a New Instant Secure Port Profile
ISPP Configuration from Switch Template
Enable Instant Secure Port Profile on a Port
Instant Secure Port Profiles Device Level Override
DHCP Snooping
DHCP Snooping Configuration
IGMP Snooping
Configure IGMP Snooping
Network Allocation
Static Routes
Configure Switch Engine Device Switch Stacks
Instantly Create a Switch Engine Device Stack
Configure a Switch Engine Device Switch Stack
Configure Devices
Device Management Servers
Configure Device Ports and VLAN
VLAN Attributes
Configure Device Credentials
Configure SSH
Web SSH
Push the Device-Level Configuration to the Device
Clone A Device
Monitor Switches
Clients
Diagnostics
QoS Statistics
Events
Alarms
Update Device Software
Update the Device Software Images
Troubleshoot Switches
Real Time Maps
Locate Device Utility
Establish CLI Access from ExtremeCloud IQ
Reset the Device to Default Settings
Restart Power Supply Equipment (PSE)
Switch VLAN Probe
Device Update Failure
VLAN or Trunk Issues
Switch Stack Issues
Switch Communication Issues
Use Cabletest for Switch Engine Device Duplex or Speed Issues
Resolving Configuration Discrepancies in ExtremeCloud IQ
Download Tech Support File
Web SSH
ExtremeCloud IQ
provides a way to access devices remotely using the SSH protocol from the web interface. Use the following steps access the web SSH:
The Web SSH session automatically closes if the wrong username or password is entered.
Go to
Manage
Devices
Select a device hostname to see a details panel for that device.
Select
Additional Settings
Web SSH
Enter your username and password.
Select
Connect
