A stack is two or more Switch Engine devices inserted into slots and cabled together. When onboarding stacks, you see one entry for each slot when first adding serial numbers.
Use this task to configure a Switch Engine device switch stack. If you select a default template, you must copy it by saving it as a new template. This carries all the settings in the default template and let you customize it as required.
Do not to make any changes in the default template. Always create a copy and make changes to the cloned version.
Repeat the Device Template configuration steps for each device in the stack.After the stack is configured and operational, all slots will consolidate into a single stack object in ExtremeCloud IQ. It can take up to 15 minutes for the slots to consolidate and for ExtremeCloud IQ to recognize all slots as online. You might see a red icon in ExtremeCloud IQ if slots are offline or have not yet onboarded.
