The following configuration settings are the only settings applicable to switches. All other settings displayed in this section are applicable to wireless products only.
The network policy settings that you configure depend on your requirements. For example, determine which default routing instance to use for NTP, DNS, Syslog, and SNMP for a switch.
This task is part of the network policy configuration workflow. Use this task to configure policy settings.
To configure LLDP port configurations on SR22XX, 23XX, VOSS, and EXOS devices, go to the device template or device configuration page. Configuring LLDP from this page can affect APs, XR, and 20XX/21XX switches, along with certain EXOS, VOSS, SR22XX, and 23XX Global LLDP parameters.
