Create a network policy and device template.
Under Device Configuration, you can choose to override settings made under Common Settings in a network policy. The Switch Template Override feature allows customers to create and manage switch templates based on common settings for the Switch Engine, ExtremeXOS, Fabric Engine, and VOSS platforms.
These common settings include STP, MAC Locking, IGMP, Extreme Loop Recovery Protocol Settings (ELRP), MTU, PSE, and Management Interfaces (Switch Engine only). The default values for these settings are defined within the common switch settings for each platform type. When you create a new switch template and enable the override option, you can customize device configuration settings that will override the network policy switch common settings. If the override option is disabled, the device configuration will be inherited by the network policy common settings.
If this is a switch stack, repeat this task for each device in the stack.Use this task to configure device configurations for a specific switch template.
MAC Locking must also be enabled on a per-port basis.
ELRP must also be enabled within the switch template.Select Configure ELRP Port Duration to enable the ability to define how many seconds a port stays disabled before re-enabling when ELRP detects a loop (15-600 seconds).
If VLAN attributes has enabled DHCP Snooping settings, then the VLAN attributes will override the switch template.Proceed to Port Configuration.
Section contents:
