You can configure port and VLAN configuration details and settings at the
device level. Device level settings always override any port configuration settings
that were made in the device template for a network policy. You must first
Unlock
this page in order to change the device-specific port configuration. You can also
return to the original template configuration with the Revert option.
- Only the options available to
the specific switch are displayed. For details about each option, see Configure Ports in Bulk.
- For 5520/5720
Universal Switches, VIM and partition mode are configurable at the device
level.
- LLDP/CDP, MAC
locking, STP Priority, BPDU Restrict, BPDU Restrict Recovery, Forwarding
Delay, VLAN Attributes, and Max Age are configurable at the device
level.
- BPDU Restrict and
BPDU Recovery settings are found within the STP tab.
Use this task to configure device ports and VLAN details at the device level.
- Go to .
- Select a switch Host Name to see
a details panel for that switch.
- Select the Configure
tab.
- Under Configuration,
select Port/VLAN
Configuration.
- Select Unlock to enable
switch-level configuration changes.
- Select each tab, and edit any
accessible field.
- Select Save Port
Configuration.
BPDU Restrict and BPDU
Restrict Recovery Timeout settings are found within the STP settings.
- To revert back to the network
policy switch template, select Revert to Switch
Template.
- To update the device
immediately, select Update.
- Select the type of update, and
then select Save as
Defaults to save this option as the default action.
immediately, select Perform Update.
