Use the VLAN attributes page to define additional configurations on a per-VLAN basis within a network policy. VLAN attributes are applied when the VLAN is defined within an assigned port type or when the VLAN deployment option is enabled. If dynamic VLANs are utilized, then the VLAN deployment option can be enabled within the VLAN attributes page to apply VLAN settings.
A VLAN defined within Instant Port Profiles as Non-Forwarding will not apply VLAN attributes.To create a new VLAN Attribute:
| Setting | Description |
| Use VLAN common object | Select Use VLAN common object to automatically update the VLAN NAME and VLAN ID. |
| Manual | Select Manual to customize the following
fields:
| IGMP Snooping VLAN Settings | Enable IGMP Snooping for switches
to identify ports to which multicast group member hosts are
attached in order to optimize the distribution of multicast
traffic. Note: Enable
Immediate Leave to remove
multicast host immediately when it leaves the group.
| DHCP Snooping VLAN Settings | Enable snooping of DHCP packets and creates a DHCP bindings database of IP to MAC addresses for this VLAN. Choose to enable DHCP Snooping, and the drop rogue DHCP packets action. |
| VLAN Deployments | With VLAN Deployments, VLAN and VLAN attributes can be created on switches when no port types are assigned with the defined VLAN. |
| Used By | How many devices use this VLAN. This field is system-generated. |
