A Network Policy is an assembly of configurations that ExtremeCloud IQ deploys to all devices. Because these configurations are set at the network policy level, you can apply them to multiple devices for a similar configuration. The network policy section has a Switching section for managing Switch Engine and Fabric Engine templates and settings.
Device Management settings do not put the device into device-level configuration mode as each device will likely have a unique setting (unique static IP).Network Policy configuration options are available under the main Configure tab.
Section contents:
