Extreme Networks
devices typically obtain the time and date for their internal clocks from an NTP
server. Use this task to configure an NTP server.
- Go to .
- Select an existing network policy, and then select
, or select
to create a new policy. - From the Policy Settings
menu, select NTP
Server.
- Toggle the NTP Server
setting to ON.
- Optional: To use existing NTP server
settings, choose an NTP object from the
menu. - Configure NTP Server Settings.
- To add a new NTP server to the
list, select
.- To use an existing NTP
server, select it from the
menu. - To add a new NTP server,
select
, and then select IP
Address or Host
Name. - Type a Name for
the new IP object.
- Optional: If you want to change
your previous selection, select IP
Address or Host Name
from the menu.
- Select SAVE IP
OBJECT.
- Select ADD.
ExtremeCloud IQ
accesses NTP servers in order, from the top down. Use the up and down arrows
to rearrange them if necessary.
- If you want to use
classification, select Apply NTP servers to devices via classification.
- Select SAVE NTP
SERVER.
- If you are ready to deploy the
network policy, select Next or continue to the next Management server.
