Use this task to quickly add devices to ExtremeCloud IQ from the Manage > Device List page.
To onboard a Universal Hardware Switch, for the Device OS, choose Switch Engine or Fabric Engine.Your CSV file must have at least one field containing serial numbers or service tags. Add a second field for the model numbers of the devices. For example:
Serial Number:
01234567890123
01234567890124
01234567890125
Serial Number and Model Number:
01234567890123, AP3000
01234567890124, AP410
01234567890125, AP5050
Avoid using spreadsheet applications such as Excel to create or modify a .csv file. Excel formats serial numbers that contain preceding zeros incorrectly. Many applications interpret the serial number as a numeric value, which can cause the preceding zeros to be lost and the value to be represented in scientific notation, requiring you to use special functions or convert the cell content type. Instead, use a text editor that does not format the contents.
You can only add Digital Twin devices if you are also using ExtremeCloud IQ CoPilot.
You cannot create a new location in the Quick Add process; you can select an existing location.
To add a device that was previously onboarded using an earlier version of ExtremeCloud IQ or Extreme Management Center, you must first delete the device from the older version. In these instances, you see an alert.
