Mount the AP in the desired location.
The AI-TP05360 antenna is a tri-band antenna designed for indoor use. It measures 220 mm x 69.9 mm (8.66 inches x 2.75 inches) and weighs 1.7kg (3.75 lbs).
- Unpack the antenna from the shipping materials.
- Thread the antennas onto the AP's external RP-SMA connectors.
- Tighten the antennas onto the RP-SMA connectors to a torque of 5 inch-pounds.
