Install AIO-TS06360-N
Mount the AP in the desired location.
AIO-TS06360-N
The AIO-TS06360-N antenna.
AIO-TS06360-N is an Omni-directional antenna. It measures 20 mm x 350 mm (0.78 inches x 13.77 inches) and weighs 0.14kg (0.309 lbs).
  1. Unpack the antenna from the shipping materials.​
  2. Attach the antenna to the appropriate "N" connectors.
    Tighten the connectors to 20 inch-pounds. See the AP installation guide for information on connecting the antenna to the correct ports.
