Antenna Installation Workflow
Use the information in the following table to help you install your antenna.
Table 1. Installation Work flow
StepsActionPurpose
1.Verify the box contents. Ensure that you have all of the necessary parts. The box components vary by antenna but they generally include an antenna and mounting hardware.
2.Install the antenna. Assemble the antenna bracket. Connect the AP to antenna.
3.Form a drip loop.The drip loop prevents water from entering the AP by channeling water down and away from the connection points.
4.Weatherproof the antenna connections.RP-SMA connections should be weatherized if used outdoors.
5.Confirm the antenna and AP function.Ensure that your antenna and AP work as expected.
