Polarized Panel
A polarized panel antenna is a multi-port panel antenna with different linear polarization alignments on the different ports. Common polarization alignment orientations are Vertical/Horizontal and Vertical/ 45°-Slant. Polarized panel antennas are useful on outdoor Line-of-Sight links, and are also used in indoor deployments for improved coverage uniformity at the expense of slightly reduced range.
