Install AIO-TQ14035-N
Mount the AP in the desired location.
AIO-TQ14035-N Antenna
AIO-TQ14035-N antenna
The AIO-TQ14035-N antenna is a dual polarized panel antenna. It measures 305 mm x 305 mm x 25 mm (12.00 inches x 12.00 inches x 0.98 inches) and weighs 2.3 kg (5.07 lbs). It ships with a mounting bracket.
  1. Unpack the antenna from the shipping materials.​
  2. Assemble the mounting bracket.
    The pivot screws should be only finger-tight.​
  3. Mount the mounting bracket to the wall or pole.
    Tighten the non-pivot mounting hardware to 45 inch-lbs and tighten the pole cable strap screw so they are tight and cannot be moved on the pole.
  4. Assemble the antenna to the mounting bracket using 4 nuts.
    Tighten the nuts to 45 inch-lbs.
  5. Attach the 4 cables to the AP for the specified frequencies.
    Tighten the N connectors to 20 inch-pounds.See the AP installation guide for information on connecting the antenna to the correct ports.
  6. Adjust the mounting bracket angles so the panel antenna is pointing in the desired direction.
    Tighten the pivot screws to 50 -inch lbs.
