The following table lists available antennas and the AP that support the antennas. Click on the antenna part number to read the technical specifications.
ACC-CBL-BRKOUT-12RPSMA breakout cable is available for theAP5022FX. Use the ACC-CBL-BRKOUT-12RPSMA breakout cable when you need to connect several external antennas. The cable has a 12-port Reverse Polarity SMA (RP-SMA) connector, LMR-100 cabling, and is 9 in. long.
| Antenna Part Number | APs | Notes |
| Indoor Antennas | ||
(WS-AI-DQ05120) | AP4020X | Panel antenna |
| ML-2452-SEC6M4-036 | AP4020X AP3020X | Panel antenna |
| ML-2452-APA-02 ML-2452-APA2-01 | AP3020X | Dipole antenna Two ML-2452-APA-02 are included with the AP3020X. (The two antennas are identical, but the ML-2452-APA-02 is black and the ML-2452-APA-01 is white.) |
| AI-TS06360 |
AP4020X AP4020FX AP5022FX | Omni antenna |
| AI-TQ08055 |
AP3020X AP4020X AP4020FX AP4020FX AP5022FX | Panel antenna |
| AI-TQ06120 |
AP3020X AP4020X AP4020FX AP5022FX | Panel antenna |
| AI-TH08055 |
AP4020FX | Panel antenna |
| AI-TH06120 |
AP4020X AP4020FX | Panel antenna |
| AI-TH14035 |
| AIO-HQ17020 |
AP4020FX AP5022FX | Indoor use panel antenna. For outdoor use, the connectors must be weatherized. |
| AI-TP05360 |
| Indoor and Outdoor Antennas | ||
| AIO-DQ15021-RPSMA |
AP4020X AP5022FX | Panel antenna |
| AIO-DD05120-RPSMA |
AP3020X AP4020X | Panel antenna |
| AIO-DD75060-RPSMA | AP3020X AP4020X | Panel antenna |
| AIO-TS06360-N |
AP4060X | Omni antenna |
| AIO-TQ08055-N |
AP4060X | Panel antenna |
| AIO-TQ14035-N |
| AIO-TQ06120-N |
| AIO-HQ17020-N |
AP4060X |
Panel antenna |
