AP Certificates RSA Keys
RSA is an algorithm for public key cryptography. It's the first
algorithm known to be suitable for signing, as well as encryption.
The RSA Keys screen displays a list of RSA keys installed in the selected access point. RSA Keys are generally used for establishing a SSH session, and are a part of the certificate set used by RADIUS, VPN and HTTPS.
To view the access point's RSA Key details:
- Select the Statistics menu from the Web UI.
- Expand the System
node from the navigation pane (on the left-hand side of the screen). The
System node expands to display the RF Domains created within the managed
network.
- Expand an RF Domain node, select a controller or service platform, and
select one of its connected access
points. The access point's statistics menu displays in the right-hand
side of the screen, with the Health tab selected by default.
- Expand the Certificates menu.
- Select RSA
Keys.
The screen displays by default right-hand pane.
The RSA Key Details field describes
the size (in bits) of the desired key. If not specified, a default key size of
1024 is used.
The RSA Public Key
field describes the public key used for encrypting messages. This key
is known to everyone.
- Periodically select Refresh to update
the screen's statistics counters to their latest values.
