WLAN Override VLAN Configuration
  1. Select the Override VLAN tab.
    The Override VLAN main screen displays. This screen lists existing WLAN to VLAN assignments.
    WLAN Override - Override VLAN Screen
  2. Review existing WLAN to VLAN assignments to determine if new assignments need to be added or existing configurations warrant modification or deletion.
  3. Select Add to create a new WLAN to VLAN assignment. Or, select an existing configuration and click Edit to modify it.
    The VLAN Overrides screen displays.
  4. If creating a new WLAN to VLAN assignment, use the WLAN drop-down menu and select the WLAN.
  5. In the Override VLAN table, click + Add Row to create a new client limit for a specific WLAN and VLAN, or click Edit to modify an existing configuration.
  6. Optionally define a VLAN‘s wireless client limit override configuration.
    VLANS
    Set a virtual interface ID (1 - 4094).
    Wireless Client Limit
    Set the number of users permitted on the VLAN. Set the value to 0 to have an unlimited number of users.
    A blue override icon (to the left of a parameter) defines the parameter as having an override applied. To remove an override go to the Basic Configuration section of the device and click Clear Overrides. This removes all overrides from the device.
  7. Click OK to save the changes and overrides.
