To configure WLAN security settings for a T5 controller and its connected CPEs:
| Pre-Authentication | Select this option to invoke the use of pre-authentication 802.11i fast roaming. This setting is disabled by default. |
| Enable | Select this option to enable the Security Type and WEP Encryptions Type drop-down menus used to define and apply different encryption and authentication settings to the T5 WLAN security configuration. |
| Security Type | Use the drop-down menu to select the security type to apply to the WLAN. Options include static-wep (default), wpa-enterprise, and wpapersonal. |
| WEP Encryption Type | If static-wep is selected as the Encryption Type, use this setting to apply either a WEP 64 or WEP 128 encryption algorithm to the T5 support WLAN configuration. |
| Encryption Type | If wpa-enterprise or wpa-personal is selected as the Encryption Type, use this setting to apply either a CCMP, TKIP or TKIP-CCMP encryption algorithm to the T5 controller WLAN security configuration. |
| HEX | If you are using static-wep, provide the 10-26 character Hex password used to derive the security key. |
| Passphrase | If you are using static-wep, enter either an alphanumeric string of 8 to 63 ASCII characters or 64 HEX characters as the primary string both transmitting and receiving authenticators must share. The alphanumeric string allows character spaces. The string is converted into a numeric value. This passphrase saves the administrator from entering the 256-bit key each time keys are generated. |
| PSK | Enter either an alphanumeric string as the primary string both transmitting and receiving authenticators must share. The alphanumeric string allows character spaces. The string is converted into a numeric value. This passphrase saves the administrator from entering the 256- bit key each time keys are generated. |
| Verison | If wpa-enterprise or wpa-personal is selected as the Encryption Type, use this setting to apply a WPA or WPA2 encryption scheme to the T5 support WLAN configuration. |
Select Reset to revert to the last saved configuration.
