To define a dynamic routing configuration:
Set the following OSPF Settings:
Priority |
Select this option to set the OSPF priority used to select the network designated route. Use the spinner control to set the value from 0 - 255. |
Cost |
Select this option to set the cost of the OSPF interface. Use the spinner control to set the value from 1 - 65,535. |
Bandwidth |
Set the OSPF bandwidth from 1 - 10,000,000 KBps. |
Set the following OSPF Authentication settings for the dynamic route:
| Chosen Authentication Type |
Select the authentication type used to validate credentials within the OSPF dynamic route. Options include simple-password, message-digest, null and None. |
| Authentication Key |
Enter and confirm the authentication key required by connecting nodes using the OSPF dynamic route. |
Select the + Add Roww button (at the bottom of the MD5 Authentication table) to add the Key ID and Password used for an MD5 validation of authenticator credentials.
Use the spinner control to set the OSPF message digest authentication key ID. The available range is from 1 - 255. The password is the OSPF key either displayed as series or asterisks or in plain text (by selecting Show).
Select OK to save the changes to the configuration. Select Reset to revert to the last saved configuration
Print
this page
Email this topic
Feedback
