authorization
      Configures AAA TACACS authorization
         parameters. This feature allows network administrators to limit user accessibility and
         configure varying levels of accessibility for different users.
            - Access Points — AP410i/e, AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562,
               AP7612, AP7632, AP7662, AP8432, AP8533
- Service Platforms
               — NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
         authorization [access-method|allow-privileged-commands|server]
         authorization access-method [all|console|telnet|ssh] {(console|ssh|telnet)}
         authorization server [<1-2>|preference]
         authorization server <1-2> [host|retry-timeout-factor|timeout]
         authorizationserver <1-2> host <IP/HOSTNAME> {secret [0 <SECRET>|2 <SECRET>|
<SECRET>]} {port <1-65535>}
         authorization server <1-2> retry-timeout-factor <50-200>
         authorization server <1-2> timeout <3-5> {attempts <1-3>}
         authorization server preference [authenticated-server-host|authenticated-server-number|
none]
      Parameters
                     | access-method | Configures the access method for command authorization |
                     | all | Authorizes commands from all access methods |
                     | console | Authorizes commands from the console only |
                     | telnet | Authorizes commands from Telnet only |
                     | ssh | Authorizes commands from SSH only |
                     | {console|ssh|telnet} | Optional. Configures more than one access method for command
                        authorization |
         authorization allow-privileged-commands
                     | allow-privileged-commands | Allows privileged commands execution without command authorization. This
                        option is disabled by default. |
         authorization server <1-2> host <IP/HOSTNAME> {secret [0 <SECRET>|2 <SECRET>|
                     | server <1-2> | Configures a TACACS authorization server. Up to 2 TACACS servers can be
                           configured
                           <1-2> – Specify
                              the TACACS server index from 1 - 2. |
                     | host <IP/HOSTNAME> | Sets the TACACS server‘s IP address or hostname |
                     | secret [0 <SECRET>| 2 <SECRET>|<SECRET>] | Optional. Configures the secret used to authorize with the TACACS
                           server
                           0 <SECRET> –
                              Configures a clear text secret2 <SECRET> –
                              Configures an encrypted secret<SECRET> –
                              Specify the secret key. The shared key should not exceed 127
                              characters. |
                     | port <1-65535> | Optional. Specifies the port used to connect to the TACACS server
                           <1-65535> –
                              Specify a value for the TCP authorization port from 1 - 65535. The
                              default port is 49. |
                           configured
                           <1-2> – Specify
                     | retry-timeout-factor <50-200> | Configures the scaling of timeouts between consecutive TACACS
                        authorization retries
                           <50-200> –
                              Specify the scaling factor from 50 - 200. The default is 100. A value of 100 indicates the interval between consecutive retires
                           remains the same irrespective of the number of retries. A value
                           lesser than 100 indicates the interval between consecutive retries
                           reduces with each successive retry. A value greater than 100
                           indicates the interval between consecutive retries increases with each
                           successive retry. |
                           configured
                           <1-2> – Specify
                              the TACACS server‘s index from 1- 2. |
                     | timeout <3-5> | Configures the timeout, in seconds, for each request sent to the TACACS
                        server. This is the time allowed to elapse before another request is sent to
                        the TACACS server. If a response is received from the TACACS server within
                        this time, no retry is attempted.
                           <3-5> – Specify
                              a value from 3 - 5 seconds. The default is 3 seconds. |
                     | attempts <1-3> | Optional. Indicates the number of retry attempts to make before giving
                           up
                           <1-3> – Specify
                              a value from 1 - 3. The default is 3. |
none]
                     | preference | Configures the authorization server preference |
                     | authenticated-server-host | Sets the authentication server as the authorization server This
                           parameter indicates the same server is used for authentication and
                           authorization. The server is referred to by its hostname. |
                     | authenticated-server- number | Sets the authentication server as the authorization server This
                           authorization. The server is referred to by its index or
                        number. |
                     | none | Indicates the authorization server is independent of the authentication
                        server |
         nx9500-6C8809(config-aaa-tacacs-policy-test)#authorization allow-privileged-commands
         nx9500-6C8809(config-aaa-tacacs-policy-test)#show context
aaa-tacacs-policy test
 authentication directed-request
 accounting server preference authorized-server-number
 accounting auth-fail
 accounting commands
