auto-create-rfd-template
      Enables auto creation of an RF Domain:
          - when tokens are used to select the RF Domain to apply to devices matching the adoption
            criteria, and
- the token-specified RF Domain does not exist.
During device adoption, if the token-specified RF Domain (configured using the ‘adopt‘
        rule) is not found, the system auto creates a new RF Domain based on an existing RF Domain
        template specified using this command. This option is disabled by default.
            - Access Points — AP410i/e, AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562,
               AP7612, AP7632, AP7662, AP8432, AP8533
- Service Platforms
               — NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
      auto-create-rfd-template <RF-DOMAIN-NAME>
    Parameters
              | auto-create-rfd-template <RF-DOMAIN-NAME> | Auto creates a new RF Domain based on an existing RF Domain
                  template
                  <RF-DOMAIN-NAME> – Specify the RF Domain name (should
                    be existing and configured). The new RF Domain created is
                    saved with the token name specified in the ‘adopt‘
                    command. |
      The following example configures an adopt rule for adopting any AP7532 and applying an RF
        Domain matching the token “$MODEL[1:5]” to the adopted
        AP:
nx9500-6C8809(config-auto-provisioning-policy-test)#adopt ap7532 precedence 20
rf-domain $MODEL[1:5] any
nx9500-6C8809(config-auto-provisioning-policy-test)#show context
auto-provisioning-policy test
 adopt ap7532 precedence 20 rf-domain $MODEL[1:5] any
The following example enables auto creation of an RF Domain using an existing RF Domain
        ‘rfd-AP‘ as template:
          - RF Domain name “AP-75”: Applicable to any AP 7532nx9500-6C8809(config-auto-provisioning-policy-test)#auto-create-rfd-template AP-75 nx9500-6C8809(config-auto-provisioning-policy-test)#show context
 adopt ap7532 precedence 20 any
 auto-create-rfd-template rfd-AP
            As per the above configurations, when an  AP 7532 comes up for first-time adoption, the system:
                - Checks for an RF Domain matching the options provided in the ‘adopt‘ rule, and
                  if not found
- auto creates the RF Domain only if:
                    - A token is specified in the ‘adopt‘ rule. For example, $MODEL[1:5], and
- the ‘auto-create-rfd-template‘ option is configured
- Uses the ‘RF Domain‘ specified in the auto-create-rfd-template command as a
                  template. Therefore, the specified RF Domain should be existing and
                  configured.
- Applies the new RF Domain to the AP.
Related Commands
              | no | Disables auto creation of an RF Domain |
