Creates an IoT Device-Type Imagotag policy and enters its configuration mode. Use this option to enable support for SES-imagotag‘s Electronic Shelf Label (ESL) tags on WiNG APs with USB interfaces.
ESL tags are small, battery-powered devices used by retail businesses to display information, such as product code, pricing, etc. These tags are activated, configured, and managed through an SES-Imagotag provided server. The tags and server communicate through an ESL communicator (a USB dongle), connected to the USB port on the WiNG AP. This communication is over the 2.4 GHz band using a proprietary RF protocol. The ESL communicator acts as a bridge between the tags and the server, using WiNG AP as an infrastructure device.
This policy, when applied on an AP, enables the AP recognize the ESL communicator, and facilitate communication between communicator and tags.
The policy can be applied to the AP‘s self (in case of stand alone AP), or pushed to the AP through the adopting controller. In the latter case, apply the policy on the AP‘s profile.
iot-device-type-imagotag-policy <POLICY-NAME>
| iot-device-type-imagotag-policy <POLICY-NAME> | Specify an IoT Device Type Imagotag policy name. If another policy by the specified name does not exist, the policy is created. |
nx9500-6C8809(config)#iot-device-type-imagotag-policy ImagoTagPolicy nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#? Iot Imagotag Policy Mode commands: channel Auto channel selection enable Enable ESL communicator fcc-mode Enable fcc compatibility mode on ESL communicator no Negate a command or set its defaults output-power Maximum output power payload-size Configure payload size server ESL server ssl Enable ssl on ESL communicator window-size Configure window size clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#
| no | Removes the specified IoT Device Type Imagotag policy |
